TractorLinks.com
Show Parts for Model:
Re: D19 front on a D17
maple hill sugar bush
12-09-2013 20:19:54
I meant to say that I break an axle off of the spindle instead of break a spindle. I was assuming/hoping the D19 FE would have a heavier axle/spindle. Gatz I did forget to mention my brother did weld in gussets as you described. That was after he busted one of the spindle tubes off. Diydave you are right about that it is not that expensive to change a spindle. It always seems to break when I need it the most though and that is what I would like to avoid. But if the D19 FE is no stronger I would not gain anything. I have a 1/2 mile long driveway to clear and log about 10 cords of wood a year mostly in the winter off my property in NE MN. I guess I should get a spindle to keep on hand to reduce down time.
Diydave
12-10-2013 04:37:01
 Re: D19 front on a D17 in reply to maple hill sugar bush, 12-09-2013 20:19:54
I have a D-12 with a big drum mower on the back, and about 350# of weights plus wheel weights on the front. Put a 5 lb sack of sugar on the back of the mower in transport position, and it will do a slow wheelie! I generally break a spindle, every other year, $233+ shipping, from Sandy lake. Normal procedure is to steal a spindle off of the D-10, order the new one while putting the used one on the D-12. Whole procedure was about an hour, last time I had to do it, LOL! If you measure the spindle diameter, and axle diameter, and post it here, I'm sure someone that has a 19 can post it, too. That way you'll know the differences.
12-10-2013 09:09:55
 Re: D19 front on a D17 in reply to Diydave, 12-10-2013 04:37:01
Do you think the AC spindle is stronger than an after market one?
The spindle drawings on this site show all the measurements. Assuming they are correct they show the only difference between a D17 and D19 is the length.
12-16-2013 08:12:26
 Re: D19 front on a D17 in reply to maple hill sugar bush, 12-10-2013 09:09:55
I just realized after looking at the spindle drawings again that early model D17 had a 1.5 inch inner axle bearing seat and later model had 1.625. The later model is the same as the D19. So it seems like I could beef up my front end with later model spindles, hubs, bearings, and wheels. I wonder if the additional 1/8 is enough to reduce axle breakage?
Diydave
12-10-2013 16:56:36
The ones I have been buyin for the D-12 are aftermarket. I think Its about $100 +/- more for an AC original. Talk to Brenda @ Sandy Lake, for more info!
