Show Parts for Model:
Re: b-125 crank kit
12-09-2013 15:11:29
If the crank was turned to fit the new bearings, then you dont need shims on the rods... measure to make sure. YOu will still need shims on the main bearings as the block and caps were not line bored.
Dick L
12-09-2013 16:05:58
 Re: b-125 crank kit in reply to steve(ill), 12-09-2013 15:11:29
Nope Steve. The big end of the rod is not round. The hole is only round with shims. You clamp and measure the old rod, before reconditioned, it will be wider than it is high.
tim lockey
12-10-2013 19:38:15
 Re: b-125 crank kit in reply to Dick L, 12-09-2013 16:05:58
Thanks for helping me understand this Dick L checked w/ plastigage, way too tight, crank wont rotate, this with STD as new crank, and STD bearings. Where can i order the correct shims for both mains and rods? No AC dealers left in eastern NC. Thanks
12-12-2013 18:55:41
 Re: b-125 crank kit in reply to tim lockey, 12-10-2013 19:38:15
If the crank was "standard" and the bearings are "standard", then you will need about .006 inch of shims on each bolt. They sell .002 shims ( x 3) or like DIck said, you can cut you own. I have a brass sheet .002 thick and have made several. The shim goes around the bolt, but dont get it caught under the edge of the bearing.
Dick L
12-11-2013 10:13:38
You can get them from Sandy Lake Implement and you might get them from this site. I cut my own from shim stock. Some cut them from pop cans.
The shim packs you get from a dealer would be easier for someone that has not done this before.
