TractorLinks.com
Show Parts for Model:
Re: b-125 crank kit
Dick L
12-08-2013 06:49:03
Missed thinking about your question at first. Answer is you have not done anything wrong by having the crankshaft ground and bearing matched. That is all good with or without shims. If it had shims when you took it apart it will need shims to go back together unless you did as stated below. If it did not have shims when you took it apart you will need to mic the journals ID to make sure they have been reconditioned and the person working on it before put it together with out shims to take up the slack from wore out crankshaft and bearings.
