james wacker
New User
cultivator lift dosent lift all the time on my c allis ...it has a rebilt cylinder and pump that gets 20 weight oil from rear end ...frustraded
James! If your oil level is full, and your pump was just rebuilt, by some one who knew his stuff, Then pull your pump off and check for an obstruction at the pump intake pipe. Maybe a plugged screen? I have a 52 B , that had worn cam lobes ,and wouldn't push the pump arms far enough to make it pump well. After the 3rd pump, I gave up, pulled the pump, blocked the hole with a homemade plate, and mounted a gear pump ahead of the radiator, and put modern live hydraulics on it. Expensive? YES! Best thing I ever did! It is my go to tractor now.
