185 Hydraulic problem
Ted worm
New User
I have a 185 tractor. I ran low on hydraulic oil, I added about a gallon and a few days later I was low again. there are no leaks visible anywhere. I noticed the oil level for the transmission is high. Has anyone had a leak from the hydraulic leaking into the transmission. I thought I would ask before I tear it apart Thanks
Seal is out behind the Powerdirector ; where the pinion shaft goes thru, while its apart replace the pto seals, it takes 2 of them, 185,s are pretty easy, bout a 6 hour job
