Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
wobble in B arch front end ?
farmallstrong
12-01-2013 19:18:58
108.32.28.60
How do you repair the wobble in the spindle shafts? There doesn't seem to be any bearings and the shaft wobbles about 1/4". Thanks
[Reply]   [No Email]
Roger H.mi
12-07-2013 19:18:09
50.36.100.236
 Re: wobble in B arch front end ? in reply to farmallstrong, 12-01-2013 19:18:58
You need to replace the upper and lower bushings on the wishbone axle and weld up and turn down the spindle to a tight fit. Also you can replace the pivot stud.
[Reply]  [No Email]
Pecosallis
12-02-2013 18:24:41
75.104.39.188
Had wobble in my B front end also, like the previous comments said the bushings were worn, the other thing was right under the engine at the front there is a square headed bolt that needs to be welded to the flat area there. The wishbone is bolted to that, if it is loose (weld broken like mine was) there is alot of wobble in the front end. Also at the bell housing the hole at the bottom where the front end support bolt goes thru needed a bushing also. Now no more wobble. I got the parts from this site and Tonys tractors. These are flat and thin and look like they are not there but reminants of them are and need to be taken out prior to inserting the new ones.
[Reply]  [No Email]
Ted in NE-OH
12-02-2013 07:52:08
65.25.30.63
There is bushings at the top and bottom that can be replaced. If the king pin itself is worn it can be welded up and turned down at a machine shop.
[Reply]  [No Email]
steve alderman
12-02-2013 06:18:56
68.37.60.149
there might be a bushing in there that's worn out and needs to replaced
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
