Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Help - WD45 Transmission Problem
JMS/.MN
12-01-2013 08:41:35
Pull the rubber boot up, find a snap ring that holds the shift lever in place. remove that and pull the lever out. Reach in with a long screwdriver and align all three shift collars so the slots line up. Replace lever and snap ring.
ACEd
12-03-2013 19:49:02
 Re: Help - WD45 Transmission Problem in reply to JMS/.MN, 12-01-2013 08:41:35
OK - did as suggested, shifted with some effort but feels loose - then poped out again - seems like there is a wear issue - not sure if its ball or the tip of shifter - any thoughts appreciated.
ACEd
12-03-2013 19:51:48
 Re: Help - WD45 Transmission Problem in reply to ACEd, 12-03-2013 19:49:02
PS - on looking doen at tops of rails there seems to be a gap between 3-4 rail and R rail that may be wide enough to let shifter go thru. Is this a problem with rails or is tip of shifter too thin - but shifter tip does not look that worn.
