Power adjust wheel lock
There were 2 types of locks, as I recall, some had the wheel stops drilled 90 to the rim, and some had the hole drilled 90 to the rail. I believe as long as you replace like for like, it will work.
Thanks for the reply Dave, that is what my wife thought,
I hate it when she is right, I found some off a WD and I was not sure if the rails were larger than the CA.
Thanks again.
Bruce.
I think rail size is the same, but the hole angle is the critical issue. You might also want to check JD and MF spin out wheels, too, as they were made by license, as AC was the patent holder on spin out rims.
I've bought a couple sets of new power adjust rims, and found there are now at least three types of stops. They are playing around with the hole spacing, so even stops with the correct angle might not work. GRRRRRRRRRRRRR!
