TractorLinks.com
Show Parts for Model:
Re: milky oil in engine
Ted in NE-OH
11-30-2013 16:52:50
There are 3 freeze plugs in the top of the engine head just below the rocker shaft. Take the valve cover off and inspect. They sometimes rust through or get a pin hole. This is the easiest thing to check and fix as they just push in. Could also be head gasket. The first thing I would do is change the oil once run it an hour and change the oil again and then wait to see if it happens again. Could be just condensation.
steve(ill)
12-01-2013 06:38:40
 Re: milky oil in engine in reply to Ted in NE-OH, 11-30-2013 16:52:50
Drain the oil as mentioned and leave the drain plug out. Refill the radiator and see if it continues to drip out the bottom after an hour or two. Step two is to take off the hood and vavle cover and see what the freeze plugs under the rocker arm look like. After that, you might consider a sealer if it is head gasket or sleeve o-rings. I have had good luck with a half bottle of BARS Copper gasket sealer.
