TractorLinks.com
Show Parts for Model:
Re: hydraulics on a 1939 B
steve(ill)
11-28-2013 19:06:58
if your using a 20 wt or hytrans type oil, and NOT gear lube.... then look at the two rotating discs on the shaft of the valve/pump. When you pull, push the lever, one disc moves a little, then pushed the other disc. There are a coupe small springs and one disc is pinned to the shaft. make sure the pin is not broken, and both discs rotate freely.... If all is weell, then spring / spool inside need cleaned and rebuilt.
jgstrickland
11-29-2013 07:05:36
 Re: hydraulics on a 1939 B in reply to steve(ill), 11-28-2013 19:06:58
Gentlemen I started this thread to help a friend who wants to get his Grandfathers tractor operational again. He does not have any Manuals or anything of that sort, but was hoping that you guys could walk him through it with a picture or two as well. He will come along soon on the Forum. But I just wanted to get him started and show him that there are some very helpful info on the forum. I work mainly on Farmalls and I do also have a Ford in my collection. But I know as well as you that we all work together to solve problems. Thanks for any pictures that would helpful toward solving his problem.
Thanks in advance
James
