WyinMO
New User
I want to put a wd-45 crank in my wd. Which rods will I need to use and what else needs to be changed
I can not tell you the answer but if your name imply's where you are I have a WD45 block and well an engine that when I pulled it ran
You will have to change to Power Crater pistons or you will have more compression than you can handle. When making such a conversion, we sometimes had to grind some of the "meat" off the block so the shaft could revolve. All other internal parts fit.
If you run E85 gas can use what pistons and rods you have. This should make you 65 hp at 2000 rpm.
So the pistons and rods out of the wd will work. what is the octane rating of E-85. What will I need to do to the carb. If I'm thinking right it takes more volume of fuel to runn E-85
