Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
7060 allis hard to start
dodgin
11-25-2013 18:59:06
75.90.192.5
I HAVE A7060 that is hard to start with out using ether. The manual says check transfer pump I can"t find one.
[Reply]   [No Email]
T in NE
12-01-2013 08:01:36
75.239.158.138
 Re: 7060 allis hard to start in reply to dodgin, 11-25-2013 18:59:06
The 7580 I had was hard to start. If it was going to be needed when it was under 50 degrees out I would try to plug it in.
[Reply]  [No Email]
massey333
11-29-2013 16:57:40
209.173.189.232
I don't know why your tractor(reason)is hard to start,but A-C came out with a update kit for the fuel line that moved the pickup (suction)line to the lower crossover(balance) line making it so air couldn't get in the line.It helped mine 100% on quicker starting.We are talking 35-40Yrs.ago so a good parts man maybe needed.
[Reply]  [No Email]
teddy52food
11-28-2013 17:07:14
184.94.175.179
Chances are if ether is being used, the top rings are broken & the compression is low.
[Reply]  [No Email]
grampy
11-26-2013 17:36:49
72.36.56.51
The transfer pump is built in to the injector pump, at the fuel inlet of the injector pump. The hand pump check valves very well could be the problem, or it could be something at the inlet side of the transfer pump. The service manual refers to a residual pressure valve on the inlet side. ( way too much info to post !) The hand pump should be all you need to start it. A friend has a 7050 that won't start after it sets for a couple hours, a few "strokes" of the hand primer pump works every time. My old 7060 needs the hand pump occasionally, It's usually parked for the winter but has to do "backup" duty for feeding in the winter. It can be a "cranky" starting old devil but a block heater and the hand primer pump always works. KEN
[Reply]  [No Email]
jim_uny
11-26-2013 15:17:04
24.213.206.167
i have 7080 so it should be similiar. there is a hand primer near pump with rubber disc. if this is worn air can leak so check it with soapy water. also, it may have an electric pump from gas tank to pump. in injection pump there is also a pump to draw fuel in. if you crack injectors are you getting fuel drippin ?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
