Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: AC D17 Tractor What's it worth??
11-24-2013 17:53:54
Some info given if off base a bit. Hard the say if anything is wrong with the power director, somebody experienced with a D-17 could tell you in an instant if it is dragging more than it should. They all drag some in neutral and you will have to hold it with the brakes. With cold oil they all will load the engine just a bit and you will need to use brakes more than slightly to hold it from moving depending on what gear you have it in. With hot oil the drag should be negligible. Move the lever either side of neutral a bit and see if it eases the drag. If so it has been shimmed incorrectly. If it has been used hard and or run without oil the plates may be warped and it will drag real hard.
11-25-2013 07:44:52
 Re: AC D17 Tractor What's it worth?? in reply to Butch(OH), 11-24-2013 17:53:54
After talking with some of my Allis Chalmers friends, I concluded there is nothing wrong with the power director. I wiggled that lever around all over and there was no place where the drag was less plus it was in low gear and cold when I was messing with it.
