Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Allis c question
Ted in NE-OH
11-17-2013 20:38:21
Later C's came with distributors. The C rear axles are longer so the C is about a foot wider in the rear end. Use the hole in the side and look for the word "fire". You may have to clean the side of the flywheel with degreaser. No B's were tricycle but a lot of C's were.
11-17-2013 20:45:40
 Re: Allis c question in reply to Ted in NE-OH, 11-17-2013 20:38:21
Ok thanks Monday when I get a chance I will try to clean the flywheel and see if I can find fire on it. Thanks again
11-18-2013 20:33:13
 Re: Allis c question in reply to Rmf1066, 11-17-2013 20:45:40
If you have a manual crank handle, turn the motor slowly untill the handle is about horizontal and you will hear the magnito "snap". At that point, you look in the hole on left side of the flywheel and you should be at the TDC mark. If not, roll the motor 180 degrees and listen for the "snap" and check again. If you dont see the TDC, then stop a few degrees sooner, or after the snap and check. It helps to have someone else look in the hole while you crank .. by hand.
Dick L
11-18-2013 11:01:26
If you are going to put a distributer on it you will need to find the TDC or CENTER line as well.
Any engine with a distributer is timed to TDC for start up. Some cars need to be adjusted after start to a book setting. These engines don't.
You can find how to time a distributer below on a large thread.
