Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Allis C question
Rmf1066
11-10-2013 18:29:32
Ok. Is there a certin type of materal that would work best or just a thin piece of sheet metal under the clamp. I tried to weld on one and grind it back down to make it tighter but I'm not that good welding cast. One more question on that tractor. Years ago we replaced the engine with one off of a silage blower and now there is not much adjustment in the throttle idle or wide open. Did the blower have a different gov then a tractor. I ordered a new gov for it and it did not fit looks like it was converted from a mag to a distributer and I needed to order one for the mag to fit rite. Any thought what I can to to help with the throttle.
steve(ill)
11-13-2013 18:45:13
 Re: Allis C question in reply to Rmf1066, 11-10-2013 18:29:32
for throttle adjstment, take the rod from the carburetor to the horizontal arm behind the radiator off at the radiator end. Put the throttle lever to wide open. The spring on the governor will pull the horizontal arm tight and it will move away from the thermostat housing toward the radiator. Now take the rod from the carburetor and hold it up to the hole in the arm. You should have to stretch a few thousands to get the rod into the arm. If the hole is not in the right place, then you bend the arm forward or back untill the rod end just slides into the arm... That should sync the governor to the carburetor.
chalmersbob(pa)
11-10-2013 19:38:07
I cut galvanized strips a little longer then the clamp and fold the ends to a 90 degree bent so they didn't slip out.
Extra eccentrics will not make any difference, see picture. LOL Bob
Ted in NE-OH
11-10-2013 18:43:40
Brass is best , won't rust. If not brass, use beer can.
