CA hydraulics
OldMoIron
I have a CA that has a brushhog 3pt cant get it to hold, either it slowly raise or it lowers. Im not having any luck trying to find if there id certain adjustment to make.
normally you put a block or chain to form a "STOP" at the bottom. Drop it and let it set at a predetermined spot for mowing.
Common problem with many of the A/C tractors. I have a WD45 and D-17 that both do that so a limit chain is pretty much needed so you let it down and the chain holds it where you want it and the hyd lever is all the way down that way
