TractorLinks.com
Show Parts for Model:
Re: Can you ID this for me?
ACEd
10-24-2013 12:54:06
I"m in Louisiana - too far to be practical and I don"t really need a stuck engine even at that price. I already have a stuck D17 engine - hence the interest.
As to the 6 cyl AC - most likely off a combine or similar - there was a gas 6cyl based on the buda 6cyl diesel used in WD45 & D17.
As for the 4 cyl diesel - there you may be in luck - I am pretty sure there was a D15 diesel but I don"t have that info with me right now. I"ll try to find details tonight.
best, ed
ACEd
10-25-2013 14:04:15
 Re: Can you ID this for me? in reply to ACEd, 10-24-2013 12:54:06
D15 Diesel was 175 ci 4cyl - 3.5625 bore x 4.375 stroke - introduced in D15 Series I but same engine continued to Series II - it did not change displacement like the gas D15. If you are lucky enough to find one, it probably would bolt in to a D14 or D15 with minor if any mods.
Joe r
10-26-2013 07:27:24
 Re: Can you ID this for me? in reply to ACEd, 10-25-2013 14:04:15
Hey AceD,, Do you know what the letter designations are for the 4 cylinder diesels that will work on the D14? I downloaded a list of engine serial numbers but list does not identify which are gas or diesels. I'm not having much luck locating a 149 gas engine so maybe a 4 cyl diesel be easier to locate,,,?? I'm goin to go ahead and take the 149 block out of tractor so I can assemble on a stand should I ever find the parts. thanks Joe r
ACEd
10-26-2013 08:07:13
 Re: Can you ID this for me? in reply to Joe r, 10-26-2013 07:27:24
I've never seen one in person - i think they are much more rare than the gas engines. As for designation I would guess it could be a D175 since time frame was similar to G226 etc. As to markings on block, I think the D15 gas engines were stamped 15- plus serial number with suffix on edge of flange on left side where attaches to trans housing. I'd look for something starting or ending with D.
Joe r
10-25-2013 15:01:57
Hey Ed,,, Man,, you got me salivating there for a while, my friend,,,thinking I was goin to power the tractor with a diesel. So, I go out there and look, and look and look for the 4 cylinder diesel he told me had,,,,,,,,,but all I find is a 6 cylinder diesel with a turbo,,,but no 4 cylinder diesel. RATZZZ. called him back but he did not really know if it was a 6 or a 4,,!!!
I went ahead and got what numbers I could if any body here has an interest in them. He has two 6 cylinder gas engines and one 6 cylinder diesel with a turbo. thanks for your help, Ed.
