AC H-3 DOZER
tom38
New User
I have heard and I hope someone can tell me for sure. Will a D14 radiator interchange with a H-3 dozer radiator thanks for your help. tom
Tom,
If the question is whether it will adequately cool then yes, engines are very close. As to fit, let me know what measurements you need and I can give them to you. I have two D14s apart right now.
Thanks,
Chris
Chris the measurements are 19&one eighth wide by 23&three fourths high to the top of the filler tube. it has two mounting nuts on each side 6&one fourth inches apart & also has two heavy mounting pads on the bottom of the radiator, but the pads on the bottom are not used on the H3 just the side bolts which are fine thread. thanks again tom
