Transmission
Anonymous-0
I have a 1939 B Allis that is quiet in 1,3, and reverse, but sounds like a bearing is about to crater in 2nd gear.
Are bearings available for a complete transmission overhaul?
Is a transmission overhaul difficult to do?
Can I continue to drive it if I don't use 2nd gear?
Thank You
The same bearings are in use in the transmission for several "gears". If one "gear" is noisy, likely it as a gear (tooth) issue rather than a bearing issue.
Had this happen to a WD. Dealer said was wearing through the hard surface of the teeth of 2nd gear. It was the gear used for plowing and disking.
I have a complete set of transmission innards from a C from 41, should be the same as yours. I would be happy to send them to you if you will pay for the postage as I would like to get them off my shelf and don't want to scrap them.
Zach
