farmer bob899
New User
does any one have an answer for this. less than 1000 hrs on engine overhaul. last summer ran water in radiator all summer when hose blew and lost all antifreeze come time to put her away for winter drained water filled with antifreeze didn"t even get to storage barn antifreeze low and in the oil come spring get her out. did radiator pressure test 15 lbs for 3 days with oil pan off no leaks up to 20 lbs over night still no leaks put oil pan back on filled with water ran all summer mowed about 250 acres of hay didn"t have to add to radiator at all and ran like a top all summer. drain water add antifreeze for winter storage. you guessed it antifreeze back in oil does any one ever had this happen before seems like if it was a head gasket or a sleave o ring it would do this all the time I even put a new turbo on it
