12v Convert of AC WC
48C-MAN
I have a 6v pos ground WC backwards loader that I am switching to 12v pos ground. Other than the coil, alt., batt. and light bulbs this tractor has an ignition switch with a starter solenoid. My question is do I need to rewire anything with the switch and do I need a different solenoid?
No you do not have to do any thing else. Shoot you can keep that coil if you add a ballast resister like the O'Reilly's VR-1
IF you haven't already found it, there's a pretty good set of instructions and a wiring diagram for converting a Farmall M. The WC would have a virtually identical electrical system.
Forgot the say if your going with an alternator you have to switch the ground from + to - or your new alternator will not last a split second
your o.k.... but check the alternator. 99% are negative ground.
http://i436.photobucket.com/albums/qq86/steve-ill/alternator-coilWireing-1.jpg
<a href="http://s436.photobucket.com/user/steve-ill/media/alternator-coilWireing-1.jpg.html" target="_blank">
alternator-coilWireing-1.jpg" border="0" alt="alternator- coil photo alternator-coilWireing-1.jpg"
</a>
