DaninKansas
What combine rims will bolt directly onto a D17? My FIL bought some (fairly cheap) that bolted directly onto his D17. The one I'm looking at buying also has rotted out rims and I thought I might try the same solution.
It seems like the you could buy a whole Gleener F (if that is the size) for the price of one power slide rim - let alone two rims and the tires. And usually those tires are in pretty good shape from being stored inside.
