TJ in KY
This is on an Allis Chalmers 175 diesel,
Does anyone have a fix for this hydraulic driveshaft from the engine crank to the hydraulic pump. I was concerned it was going to be expensive BUT it turns out the flange with isolation dampeners and the shaft, pto splined on one end, are no longer available at my local AGCO dealer
I am looking for ideas. I thought about having it bored out and new shaft made and welded to the hub, but I don't know how true it would run after welding.
Looking for ideas from any body that has done this repair or any machinist with ideas about retro fitting this hub and shaft.
