Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: How do you identify a wd 45, d 17, or gleaner engine.
Skyhighballoon(MO)
10-10-2013 07:53:02
Hi Bob! I'm still around.
Info for GAS engines (not LP, etc.):
WD45's had 6.5:1 compression ratio engines and as said had a 45-xxxxxx serial number. Oil filter was a bypass system. Rated engine speed was 1400 rpms.
All D17's had 7.25:1 compression engines and serial numbers 17-xxxxx and a -M suffix code. Early Gleaner E engines had the same 7.25:1 CR and the -M suffix. Tractor engines were rated for 1650 rpms and combines for 1600. Early D17 engines were bypass oil filter. Full flow oil system came on at tractor SN 24001 for the D17's and this was before Gleaner E combines were made so all Gleaner engines had full flow oil systems. Also the D17 crank was different with a center thrust bearing and larger mains if I remember right.
Later years Gleaner E, EIII (1968 only) combines and 170 tractors had 8:1 CR engines and had a -Z suffix code in the serial number. Rated engine speed for the tractor was upped to 1800 rpms.
175 gas tractors had a 8.2:1CR engine and a -V suffix code. Same 1800 rpms. 175 gas tractors got a larger carb intake.
Mike
borsite
10-10-2013 21:34:39
 Re: How do you identify a wd 45, d 17, or gleaner engine. in reply to Skyhighballoon(MO), 10-10-2013 07:53:02
Where to go for piston to dome height and cc of combustion chamber on the 201g and 226g Allis engines? Is compression ratio on the outside of the block?
Did Allis play around with port size in the head or intake manifold runners? Casting numbers of same?
What is the procedure the convert an older block to full flow oil filtering?
Has anyone stroked these engines? How much?
Thanks in advance for your assistance.
moretoys28
10-10-2013 14:11:53
Did the gleaner engines have the thrust bearings and larger mains or just the d 17?
Skyhighballoon(MO)
10-10-2013 15:14:04
 Re: How do you identify a wd 45, d 17, or gleaner engine. in reply to moretoys28, 10-10-2013 14:11:53
Yes, the Gleaner E/EIII 226 engines had the same internals to the D17 226 tractor engines except for the different pistons that determined the different compression ratios. Combine manuals use tractor manual pages when it came to the engine. I don't know if that purported nitride treated crank from the Series IV D17 (SN 75001 and up starting in late 1964) was done for 170/175 or Later E/ EIII combine engines....
The Gleaner block was different as stated with the mechanical fuel pump mounting location.
Also, the Gleaner combine engines had basically single speed governors for combine use (rated speed & idle, nothing in between like the tractors). So if you get a combine engine to use in a tractor, you'll need a tractor governor for a tractor application.
Mike
moretoys28
10-10-2013 16:38:00
 Re: How do you identify a wd 45, d 17, or gleaner engine. in reply to Skyhighballoon(MO), 10-10-2013 15:14:04
How do you visually tell the difference between the oiling systems?
moretoys28
10-10-2013 14:07:56
Thank you very much. That is some very useful info I appreciate it.
