Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: How do you identify a wd 45, d 17, or gleaner engine.
Bob Bancroft
10-09-2013 16:52:09
It depends. There used to be (haven't seen him in a while) a fellow on here, "skyhighballoon" I think, who had much detailed information on these engines. The WD45 was a slow, low compression engine. Over time with the D17 they upped compression and speed several times. A different cylinder head was added(the one with long reach spark plugs). The real weakness of that engine- the partial flow lube system, was updated to a higher pressure, full flow system. The last combine to use that basic engine was the EIII. I think the last tractor was the 175.
borsite
10-10-2013 21:34:39
 Re: How do you identify a wd 45, d 17, or gleaner engine. in reply to Skyhighballoon(MO), 10-10-2013 07:53:02
Where to go for piston to dome height and cc of combustion chamber on the 201g and 226g Allis engines? Is compression ratio on the outside of the block?
Did Allis play around with port size in the head or intake manifold runners? Casting numbers of same?
What is the procedure the convert an older block to full flow oil filtering?
Has anyone stroked these engines? How much?
Thanks in advance for your assistance.
moretoys28
10-10-2013 14:11:53
Did the gleaner engines have the thrust bearings and larger mains or just the d 17?
Skyhighballoon(MO)
10-10-2013 15:14:04
 Re: How do you identify a wd 45, d 17, or gleaner engine. in reply to moretoys28, 10-10-2013 14:11:53
Yes, the Gleaner E/EIII 226 engines had the same internals to the D17 226 tractor engines except for the different pistons that determined the different compression ratios. Combine manuals use tractor manual pages when it came to the engine. I don't know if that purported nitride treated crank from the Series IV D17 (SN 75001 and up starting in late 1964) was done for 170/175 or Later E/ EIII combine engines....
The Gleaner block was different as stated with the mechanical fuel pump mounting location.
Also, the Gleaner combine engines had basically single speed governors for combine use (rated speed & idle, nothing in between like the tractors). So if you get a combine engine to use in a tractor, you'll need a tractor governor for a tractor application.
Mike
moretoys28
10-10-2013 16:38:00
 Re: How do you identify a wd 45, d 17, or gleaner engine. in reply to Skyhighballoon(MO), 10-10-2013 15:14:04
How do you visually tell the difference between the oiling systems?
moretoys28
10-10-2013 14:07:56
Thank you very much. That is some very useful info I appreciate it.
