WD45 hydraulic question
Tractor is attached to 82T mower with one-way cylinder that won't lower, however will leak down in about 15 minutes; lift arms also can't be pushed down. Pump is in drawbar mode, reservoir has fluid. Is it time to rebuild the pump?
KISS time. Start with verifying valve control setting, then see if the valve is working properly.
had a friend with one like that, the dealer fixed it in a few minutes, had a spring broke in the pump. I don't know how to fix it.
