Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Continuing G rear axle seal saga
09-29-2013 03:55:36
Turns out that upon careful inspection, I see that that the right real axle had indeed been broken right at the location of the seal. There were two tell-tale signs of the break. 1) Bluing from heat generated in the weld repair of the axle and 2) the weld had been ground down to be smoother than the original machining marks and likely just as true as the original axle. Nice repair job! As they were prone to breaking, it's a wonder that they survived with a weld job. Maybe users quit doing whatever it was that was breaking axles, like probably using wide tread settings.
09-29-2013 05:38:10
 Re: Continuing G rear axle seal saga in reply to leon, 09-29-2013 03:55:36
Have you got it back together yet? Just wondering if it is going to seal this time with the new seals or if you will have to true it up to get rid of any run out. On the one I did it will still drip occasionally at a certain spot when it sets for a long period of time. It is not enough that I am going to take it back apart to try to fix. Lee
