TractorLinks.com
Show Parts for Model:
Re: carb and starter help
53ca
09-28-2013 07:00:48
ring gear loooks good the grind is on the back of it. like the starter is to close to the block. i tried to taper the teeth on the starter a little more and seemed to help a little but still marinal better. seems like it needs a shim between starter and block. was told my 12 volt on is spinning the 6 volt starter to fast and hard?
as for the carb theres no adjment on this one. yes ventra is in there.. would float be a little high?
old
09-28-2013 10:16:43
 Re: carb and starter help in reply to 53ca, 09-28-2013 07:00:48
Again I will ask what tractor hard to help you help your self with out enough info.
That said yes a bad float or a sticking one or set wrong will cause that as will a air cleaner that needs to be serviced
53ca
09-28-2013 13:55:31
 Re: carb and starter help in reply to old, 09-28-2013 10:16:43
It is my ca allis, the shut off on the tank is what i was talking about. there is no mixture screw on the carb will try pulling it apart and adjusting the float a little more. air cleaner was pulled off tractor before, put in was tank and blowen out.
any other ideas on what to do with the starer?
Stu (ON, CAN)
09-28-2013 08:06:16
I have a 12V battery with a 6V starter and no issues. You just can't run the starter too long as it will burn out quickly. I think spacing is the issue here.
Do you have a idle mixture adjustment? What 'gas valve' do you refer to? If this is the one under the tank then my guess is that you have real carb trouble! I would suggest removing the carb for a full clean and inspection. What make is the carb on your tractor?
