TractorLinks.com
Show Parts for Model:
Re: carb and starter help
chalmersbob(pa)
09-27-2013 18:17:11
If you are refering to the gas valve under the tank, you either have the wrong jet in the carb or you didn't put the venturi back in the carb.
The starter grind sounds like a worn ring gear. To repair that you must split the tractor, and either replace the gear or remove it and turn it 180 degrees. LOL Bob
53ca
09-28-2013 07:00:48
 Re: carb and starter help in reply to chalmersbob(pa), 09-27-2013 18:17:11
ring gear loooks good the grind is on the back of it. like the starter is to close to the block. i tried to taper the teeth on the starter a little more and seemed to help a little but still marinal better. seems like it needs a shim between starter and block. was told my 12 volt on is spinning the 6 volt starter to fast and hard?
as for the carb theres no adjment on this one. yes ventra is in there.. would float be a little high?
old
09-28-2013 10:16:43
 Re: carb and starter help in reply to 53ca, 09-28-2013 07:00:48
Again I will ask what tractor hard to help you help your self with out enough info.
That said yes a bad float or a sticking one or set wrong will cause that as will a air cleaner that needs to be serviced
53ca
09-28-2013 13:55:31
 Re: carb and starter help in reply to old, 09-28-2013 10:16:43
It is my ca allis, the shut off on the tank is what i was talking about. there is no mixture screw on the carb will try pulling it apart and adjusting the float a little more. air cleaner was pulled off tractor before, put in was tank and blowen out.
any other ideas on what to do with the starer?
Stu (ON, CAN)
09-28-2013 08:06:16
I have a 12V battery with a 6V starter and no issues. You just can't run the starter too long as it will burn out quickly. I think spacing is the issue here.
Do you have a idle mixture adjustment? What 'gas valve' do you refer to? If this is the one under the tank then my guess is that you have real carb trouble! I would suggest removing the carb for a full clean and inspection. What make is the carb on your tractor?
