wheel locks not tight
Anonymous-0
My ca has a spin out on it that was blasted, repaired, and painted. Now it wont tighten back up. I put large gobs of weld on the 3 tighteners but that only lasted till started going down hill any ideas what happened? can i still get new tighteners?
only had one stop on it, was there subpost to be 2?
Are you sure that you reinstalled the eccentric blocks when you put them together. They should require a bit of torque to get them tight. LOL Bob
made a mistake there are 4 ecentrics, after they blasted the wheel, and i painted it 2 coats primer, 4 coats paint. still lose did they blast to o much off? i will try a secound stop.
