Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
model B wont start
Jeffh_01
09-22-2013 23:04:35
I ran my 1939 Model B out of gas...after sitting several years i got her running great with a little tlc...it ran out of gas and now won't start...any suggestions? I'm guessing debris was sucked into the carb but I'm not sure what to do...thanks Jeff
BIG RUH
09-23-2013 09:01:37
 Re: model B wont start in reply to Jeffh_01, 09-22-2013 23:04:35
Make sure your sediment bowl is full, if there's an air gap, it won't start. you need to losen glass bowl and let it fill nad then retighten
dogleg
09-22-2013 23:39:27
Jeff, I got some sediment (rust) in mine a couple of weeks ago. You should have a drain on the engine side of the carb on the bottom. Open that drain and flush it after you have put a couple gallons in your tank, also run your needle adjuster all the way in on your jet. Make sure you count the turns and bring it back out (do this a couple times). Give that a try and if it is a hand crank, have somebody give you a tow to fire her up. Good luck:)
Jeffh_01
09-22-2013 23:42:40
 Re: model B wont start in reply to dogleg, 09-22-2013 23:39:27
Will do thanks so much!!!
