Brent in WI
Hello
The Ross box in the CA has a very worn worm gear (razor sharp) and we found a Gemmer box that appears to fit. The problem is once you put resistance on the Gemmer it is very hard to turn. We took the box apart and the gears and bearings look to be in pretty good shape. We reassembled and adjusted all tolerances and it still turns very, very hard. Can a C be that much easier to steer than a CA? Any thoughts on what we're missing or will it not work? Thanks for any responses. Brent
