TractorLinks.com
Show Parts for Model:
Re: 30 minute AC B tractor
sandman2234
09-20-2013 05:02:32
There are several things that could cause this, but typically it sounds like a fuel restriction problem, all but the 30 minute part. Thirty minutes is quite a long time for a fuel restriction especially if it shows up almost every-time you drive it, at about that same time frame. I think I would fill the tank completely and see if that changes the 30 minute time frame any. That will increase pressure on the fuel line and decrease the air capacity in the tank. If it changes things a little bit, start looking at fuel problems. If there is no change, then I would start looking at spark, but since you have changed the mag out, that should have eliminated that, unless you inadvertently used some part that is faulty. Capacitor next? , then on to the changing out of the coil with a known good one to verify that. Valve adjustment would be last resort, unless you have recently messed with that, then that priority goes way up. Good luck with it, David from jax
