AC G Implements
I recently inherited a pretty nice 48" G which was restored about 15 years ago. It"s been kept inside and still looks good, but hasn"t run in several years.
Included in the package was a 12" right-hand plow, grader blade, two shop-made ditching implements (see photos), a store-bought spike-tooth harrow which has been adapted to fit a G, and a complete cultivator mounted on the tractor. I also have an implement adjusting lever which I can"t identify.
I"m debating selling the entire outfit or possibly keeping the tractor w/mounted cultivator and selling the loose implements. I"ve done several hours of on-line research to try to determine ball-park values of this stuff and am not having much luck. My questions are:
1. Is it more advantageous to sell the tractor with all of the implements or break it up and sell things individually?
2. Are AC G implements a rarity and hard to find?
3. Based on the photos, can anyone give me a realistic ballpark estimate of what each item is worth?
Yeah, I know that last question makes your blood boil and I hate to ask it, but please cut me some slack.........I"m a JD two-cylinder tractor guy and this is my first experience with AC.
Thanks in advance for your input and I look forward to your replies.
The homemade implements probably not worth much if anything, a right hand plow you can buy for $150-$200. I'm not sure the adjusting handle is for a G, could be from something else and made to work on it but I could be wrong? If you have a full set of cultivators then that is probably the most valuable implement. The implements are probably worth more sold seperatly than with the tractor.
Pretty sure that the adjusting lever is off a Farmall Cub for the breaking plow. Looks just like the one I have on my Cub.
