Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Ac 7000 engin oil to high on stick
Dieseltech
09-18-2013 07:35:51
RoosaMaster pump is Stanadyne now. There is a small chance on the DM model pump that the shaft seals are leaking on the OD if the housing bore had burrs, tearing the rubber case seal when pressed in place. Pump may need air pressure checked with drive end up, with bearing area filled with solvent. Any air bubbles at all getting through means seal damage. Pump must have head removed to replace the rear seal if leaking.
Gordie
09-18-2013 11:12:16
 Re: Ac 7000 engin oil to high on stick in reply to Dieseltech, 09-18-2013 07:35:51
Called the diesel shop and they said they would do the test and make any repairs needed. Wont be today, I'm in the middle of 4th cutting hay this week. But that's where we'll start. Ill keep you posted of the outcome.
Gordie
09-18-2013 08:58:41
Thanks, Ill take pump back off and take it in to Diesel Equipment and have them look it over before I take tractor to dealer.
Copyright © 1997-2015 Yesterday's Tractor Co.
