TractorLinks.com
Show Parts for Model:
Re: Ac 7000 engin oil to high on stick
Gordie
09-17-2013 20:45:59
I have not pulled the injectors. I just drained out 1 1/2 gallons of fuel- oil to get level back down to full mark on dip stick after about 2 or 3 hours of use baleing round bales. Would injectors dump that much that fast?
Dieseltech
09-18-2013 04:07:17
 Re: Ac 7000 engin oil to high on stick in reply to Gordie, 09-17-2013 20:45:59
I would still pull the injectors and check spray pattern and opening pressure. Have seldom seen a Roosa DM pump seal failure as they are much heavier than DB or DC shaft/seal design. Also how many hours on engine, is blowby excessive? May want to do a compression test, if low it will not burn the fuel as it should. Had a JD 4010 once with a dead miss, high blowby. Owner didn't worry about the miss, but did get fuel in the oil bad. Was corrected only after an engine overhaul.
