TractorLinks.com
Show Parts for Model:
Re: Ac 7000 engin oil to high on stick
Dieseltech
09-17-2013 19:43:18
Allis 7000 models had the DM model Roosa pump, much heavier than the DB that 190, 200 models had. Totally different drive shaft and seal setup. Not common, but have the injectors been checked for opening pressure and spray pattern? Had a V-10 Deutz that would get fuel in oil over time, new nozzle tips fixed it.
Gordie
09-17-2013 20:45:59
 Re: Ac 7000 engin oil to high on stick in reply to Dieseltech, 09-17-2013 19:43:18
I have not pulled the injectors. I just drained out 1 1/2 gallons of fuel- oil to get level back down to full mark on dip stick after about 2 or 3 hours of use baleing round bales. Would injectors dump that much that fast?
Dieseltech
09-18-2013 04:07:17
 Re: Ac 7000 engin oil to high on stick in reply to Gordie, 09-17-2013 20:45:59
I would still pull the injectors and check spray pattern and opening pressure. Have seldom seen a Roosa DM pump seal failure as they are much heavier than DB or DC shaft/seal design. Also how many hours on engine, is blowby excessive? May want to do a compression test, if low it will not burn the fuel as it should. Had a JD 4010 once with a dead miss, high blowby. Owner didn't worry about the miss, but did get fuel in the oil bad. Was corrected only after an engine overhaul.
