Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Continuing G rear axle seal saga
09-17-2013 04:04:38
Ted, I picked p the 12456 seals yesterday at NAPA. I won't have an opportunity to install them for several days, but they sure for the world look like the correct seal. NAPA was good enough to give me full credit for the wrong, 11800, seals I had then order. Because of the seal ring worn into the shaft, as mentioned earlier, I'm going to install two per axle so for sure one of them won't happen to hit that worn location. I also have four 12" long 5/8"guide rods made up to replace the axle housing studs during the shaft installation process. When the axle is in place, I'll remove the guide rods and replace the original studs. Twice is enough to do this job!
Ted in NE-OH
09-17-2013 18:49:04
 Re: Continuing G rear axle seal saga in reply to leon, 09-17-2013 04:04:38
Fill the void between the seals with oil. The second seal will be running dry with no oil to lubricate it and wear out quickly.
09-18-2013 02:59:54
 Re: Continuing G rear axle seal saga in reply to Ted in NE-OH, 09-17-2013 18:49:04
Good idea. I'll plan to do just that, but why would this be any different that a double lip seal?
