hydraulic wd 1954 allis chalmers
Anonymous-0
please help,i blew a hose and lost alot of fluid, i replaced it but now it dont work,where do i add fluid and how do i prim it or do i need to prim pump i just bought the tractor and everything worked till this happened
Left side of the tractor, about midway, bayonet gauge near the side frame. Has "full" indicator stamped on it.
Stand on the left side of the tractor. Put your head on the seem of the gas tank and open your eyes. You should see a flat piece sitting on a cap looking thing. That is both dip stick and fill hole
thank you. I did fill from something that fits that description however it has a K on it and there was no dip stick. I'm wondering if you can tell me if I need to bleed out the lines somehow?
Only way to bleed the lines is lift and lower a few times. Just also remember the system is not live so the clutch has to be engaged to work
