Wc reversing the rear end from forklift style
Anonymous-0
Hello I just listed the other posting about how to remove the rear axels. I got them out! So now what exact ally do I have to do to the gears to make them go back the correct way? I appreciate the help.
Notice which side of the pinion that the ring gear is on and then you just need to remove the ring gear and the carrier that it is on and spin it around so the ring gear is on the other side of the pinion.
What Lonnie said. My first reading, I thot you were reversing it. That would take some grinding of the casting to make room for reversing the pinion, but since it"s already done, it"s just split, unbolt, flip, rebolt, reassemble. WD, WD45- simply unbolt, flip, rebolt. No grinding for gear clearance.
Hello do I just unbolt the 10 bolts from the casting of the rear end and pull all of the 'pig' of the rear end with the gears and flip it 180 degrees and then bolt back up?
Thanks for the info
