TractorLinks.com
Show Parts for Model:
Re: 1950 Allis Chalmers B not running properly
Harvey2
09-08-2013 14:48:05
Carburator needs a good cleaning inside, one of the passages is plugged up.
We had a B Allis that was always acting up. So one day we fixed it permanently, we traded it on a new John Deere, problem solved".
Jim Phelps
09-09-2013 11:45:28
 Re: 1950 Allis Chalmers B not running properly in reply to Harvey2, 09-08-2013 14:48:05
I would not give up my old B for one of those green machines, they cost too much to fix.
Harvey2
09-09-2013 12:55:09
 Re: 1950 Allis Chalmers B not running properly in reply to Jim Phelps, 09-09-2013 11:45:28
Mr. Phillips,
When we got rid of the B Allis our troubles were over. We didn't have to spend any thing on repairs.
In fact the dealer said he hasn't seen us since the sale of the new tractor. Dad said we didn't need any thing in the line of repairs any more.
Jim Phelps
09-10-2013 05:28:18
 Re: 1950 Allis Chalmers B not running properly in reply to Harvey2, 09-09-2013 12:55:09
First spell my name correctly how hard is that, I have had JD's never want another one in my life best of luck to you.
Harvey2
09-10-2013 09:58:16
 Re: 1950 Allis Chalmers B not running properly in reply to Jim Phelps, 09-10-2013 05:28:18
Mr. Fhelps, sorry I spelled your name rong.
Sammy624
09-08-2013 14:55:01
i have had it soaking for the past 3 days now, and i gave it a real good cleaning so i don't think that should be the problem. But yes that is a great way to fix the problem.
old
09-08-2013 15:36:40
 Re: 1950 Allis Chalmers B not running properly in reply to Sammy624, 09-08-2013 14:55:01
Is that carb the one with the brass plug sitting on top of the main jet?? I know most are. Pull that cover plug and make sure you have a good steady flow of gas out of it. Let it flow for say 3 plus minutes. Catch it to make sure it is not full of water and dirt. Almost bet your flow is poor due to a clogged jet. When cleaning a carb you need a piece of wire etc to poke in to the jets to clean them good. I use a torch tip cleaner tool for that
steve(ill)
09-08-2013 15:10:22
your running out of gas if the choke needs to be on... One of the small brass jets is plugged in the carburetor. You might boil it in hot water on the stove... then take out the jets and blow everything out.
Sammy624
09-08-2013 17:43:24
 Re: 1950 Allis Chalmers B not running properly in reply to steve(ill), 09-08-2013 15:10:22
alright thanks for all the tips, i will have to give the jet a going over to make sure it is very very clean.
