D19 hydraulic system
Ok. I am going to a sale tomorrow, so will just have to look at it. i know it has a set of spool valves so it has more than one circuit. IT was used for a split lift on a front mounted cultivator. Thanks
Might have mis - understood your question, ours had 3 levers, 2 ones bent up were double acting, one bent down worked with the traction booster system, to a single remote, used for draught control on a towed implement. One thing to remember, this is a High pressure system, will bust the heads off low pressure cylinders!
