TractorLinks.com
Show Parts for Model:
Re: WD45
old
09-06-2013 12:34:37
Check the hand clutch and make sure it lock back like it should. Also be sure the engine does not have the bolt on plate on the right side of the engine because if it does then it is a WD not a WD45
60 acre hillside
09-08-2013 17:09:51
 Re: WD45 in reply to old, 09-06-2013 12:34:37
If it is a narrow front check for wear on the front spindle assembly. The front end rests on a tapered bearing and the up and down movement from wear may wear grooves in the bearing race and cause the bearing to turn in the shaft. The costly repair is to replace the spindle assembly and the bearing along with the rectangular key. It is quite possible that the shaft will have to be replaced. I knurled the shaft where the bearing fit and shimmed the key.
