Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Allis Chalmers D17 engine smoke
grs0820
09-03-2013 15:18:08
What color is the smoke???If green you have a lepricon in you engine if black it is running to rich {to much fuel } if white this is oil, several things could cause oil smoke, It could be as simple as a valve adjustment, valve guides worn or it could just be wore slap out... Does or is the breather plugged or blow out smoke or oil??? Many questions ...need more info.....
jamesp1965
09-03-2013 20:17:59
 Re: Allis Chalmers D17 engine smoke in reply to grs0820, 09-03-2013 15:18:08
White smoke. Had set for about a year since being ran. Was fine before it sat
sid
09-04-2013 20:14:00
 Re: Allis Chalmers D17 engine smoke in reply to jamesp1965, 09-03-2013 20:17:59
It has been my experience white smoke is caused by coolant, blue is oil, and fuel is black. So possible cracked block or leaking head gasket.
old
09-03-2013 20:39:02
If it sat for a year good chance you have water in the oil from condensation and also some condensation in the cylinder. Check the oil and make sure it is not real milky looking. If it is not take it out and make it work hard for an hour or so and see if the smoke clears up
Copyright © 1997-2015 Yesterday's Tractor Co.
