XT 190 value
herk
Hello I know of a xt 190 series III that has been sitting inside for about 17 years it won"t start ( pump problems now ) was drove in the shed when parked, What is this thing worth, I don"t now how many hours it has on it . it was not used as the big tractor. Thanks Bryan
A lot of variables but plan on at least $650 on a pump rebuild , then all the seals etc are dryed out , expect a Powerdirector rebuild $2500 because of dry -O- rings - seals ; if the paints good and tires maybe $3500 tops ??
In my area an XT190 will if your lucky bring $2500 in good running shape. They where known to have a few problems with the transmissions. Knew a dealer that would not own one even if you gave it to him. I had one years ago and it cost $850 to have the injector pump rebuilt. I traded it off for 2 other machines one running one not running
