TractorLinks.com
Show Parts for Model:
Re: AC 180 diesel fuel shutoff leak
Dieseltech
08-21-2013 19:48:04
The top cover comes off, shutoff cam pulled out of the notch, then stop shaft will pull out to replace the O ring. This may fix it for awhile, but if flex ring is failing inside the pump will need repaired. Small bits will plug the return fitting and cause housing pressure to rise making more leaks. Most pumps I see are needing pilot bushing replaced also.
A.Jackson
08-22-2013 07:41:16
 Re: AC 180 diesel fuel shutoff leak in reply to Dieseltech, 08-21-2013 19:48:04
I'll try the o ring thanks. If not, do you work on these ?
Dieseltech
08-22-2013 15:23:06
 Re: AC 180 diesel fuel shutoff leak in reply to A.Jackson, 08-22-2013 07:41:16
Yes. I repair and mail pumps. Be glad to answer any questions you have, E-mail is open.
A.Jackson
08-31-2013 12:28:51
 Re: AC 180 diesel fuel shutoff leak in reply to Dieseltech, 08-22-2013 15:23:06
Thanks for answering my question about the fuel leak. I think I need to have the injector pump rebuilt. Is the R and R something a shade tree mechanic could do if you rebuilt it. I'm pretty handy and I think I've located a service manual to help in the removal and replacement. What would you charge for a rebuild of the pump? The tractor is a 1969 AC 180.
