TractorLinks.com
Show Parts for Model:
Re: ac charging system
steve(ill)
08-14-2013 19:33:56
the factory system is a 6 volt generator with a cutout relay and light switch control for charge rate. If you get a 12 volt generator, first you need to see if it is negative or positive ground or "either". You also need a 12 volt voltage regulator that matches the generator. You will no longer use the cutout relay or the light swith resistor. Power from the battery goes to the voltage regulator and two wires from the reg go to the generator.
steve(ill)
08-14-2013 19:38:25
 Re: ac charging system in reply to steve(ill), 08-14-2013 19:33:56
