Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
spin out wheel wrench
MI AC Parsons
08-11-2013 20:19:02
used to spin wheels in and out for cultivating as a kid on dad's WD. Got a D-12 that I'd like to move the wheels in a bit. Got all the lugs loose just fine, but can find nothing to fit the 9/16" square bolt on the sliders. Crescent won't do it. What do you guys use... a special A/C wrench? And where from? Thanks
Part Time Pete
08-15-2013 09:34:19
 Re: spin out wheel wrench in reply to MI AC Parsons, 08-11-2013 20:19:02
To make them a little easier to turn, the last time I had the wheels off my D-14, I drilled and tapped the cam bolts (if that's what they're called)and put in grease zerks. Now if I can remember to keep them greased
Pete
monkeywrench100
08-15-2013 02:07:19
An 8 pt socket will work. I got my set from Cornwell. AC did make a square wrench for this. They sometimes come up on ebay. I bought one for my dad for his WD.
david hamblin
08-12-2013 23:01:01
craftsman make 8 pt sockets thanks dave
MI AC Parsons
08-12-2013 18:34:07
Yep, DiyDave, it IS 1/2" and with an extender over it, got everything to move. Am looking for an 8 pt socket set, 'cause I've got 7 Allis's. Thanks for the help.
Diydave
08-13-2013 03:15:37
 Re: spin out wheel wrench in reply to MI AC Parsons, 08-12-2013 18:34:07
D10/12, and the CA's with spin outs are the only ones, that I know of that use the 1/2" square. D14 and up, came with a dual hex head, budd type adjusting wrench and handle. And they were bigger hex heads on the bigger tractors.
old
08-12-2013 19:06:37
That should be 12cpoint socket which are common as dirt. The 6 point do not work well on square head stuff but the 12 point do just fine but is it is say a 1/2 inch you need a 9/16 or 5/8s on it.
willie in mn
08-11-2013 23:12:24
In a pinch try a 12 point socket. If a 5/8" or 11/16" doesn't fit, go to your metric set, 16 or 17mm should be close enough.
Shouldn't need to loosen any lug bolts.
Willie
J Long
08-11-2013 21:41:18
I use an 8 point socket and extension with a breaker bar. Retired mechanic.
old
08-11-2013 21:03:21
Simple open end wrench is all I have ever used. Sorry them fit all wrenches are for wannabes and are made to get you by. Yes I have a crescent wrench that is on my key ring and yes it has gotten me out of a lot of things but when I want to do real work I get a true wrench in the correct size
Allis Dave
08-12-2013 07:41:45
 Re: spin out wheel wrench in reply to old, 08-11-2013 21:03:21
Find an 8 point socket set if you want to do much work on an Allis. I have a set.
