TractorLinks.com
Show Parts for Model:
Re: WC gas shut off vale
cleddy
08-10-2013 05:43:47
I had pretty good luck with some teflon packing line from a plumbing hardware store. It kind of a string that you put a couple wraps around screw with the nut off and tighten up to compress the packing.
Seems like sometimes a new replacement is just the best way to fix a real wore out one since leaking gasoline is such a bad condition to have.
cleddy
black
08-10-2013 07:04:15
 Re: WC gas shut off vale in reply to cleddy, 08-10-2013 05:43:47
Your right , the gas is dripping on the starter -- not a good thing . I 've had good luck with Teflon tape over the years , but I'll look for the proper seal --- thanks for the suggestion
cleddy
08-11-2013 04:09:25
 Re: WC gas shut off vale in reply to black, 08-10-2013 07:04:15
I did not mean Teflon tape that would be used on threads. There is a Valve Packing material like a Cord that can be used on Pumps, Valves, Hydrants & ect that is permanent once it is in the right place.
It is best to use the o-ring or tapered washers but how do you get them on without taking the knob off which is usally crimped on the screw?
Cleddy Valves and Hydrants ect
