TractorLinks.com
Show Parts for Model:
Re: Just saved a Wd
J. Everett
08-10-2013 03:20:22
Here is one that I just finished, Old had some helpful thoughts that I used. I could not find the serial number locations.
wwminc
08-10-2013 19:03:00
 Re: Just saved a Wd in reply to J. Everett, 08-10-2013 03:20:22
Nice job.
Thats how i remember the one i grew up on, which is probably why i bought this one :)
old
08-10-2013 09:04:16
Go walk to the rear of the tractor like your going to climb on. Lay your left hand on the brake cover. Your hand is sitting right above the serial number if you do that. Just below your hand is a flat spot where the numbers are hand stamped and that is why they are hard to find
wwminc
08-11-2013 09:19:02
 Re: Just saved a Wd in reply to old, 08-10-2013 09:04:16
Serial is D 69991
wwminc
08-10-2013 19:01:38
Ok..... picked it up tonight during a downpour rain storm in a clay field..... Fun Fun !!
Will get serial, must be after 53 as it doesn't have a mag.
Thanks for the links for parts.
Would like to find a complete engine, may be easier than fixing this one. Found out is has been locked up for 15 years.
I'm in Va willing to travel a bit to get one.
Wilson Ind
08-11-2013 15:11:11
 Re: Just saved a Wd in reply to wwminc, 08-10-2013 19:01:38
Have a good wd45 engine still in reversed tractor . I would part it out. Had good solid rim tires not spin-out. Also good loader it's just on backward. sell all or part. Hear the engine run before it's pulled Located southwest Indiana email open
old
08-10-2013 19:15:11
I have a 1935 JD-B that was locked up I know for sure 15 plus years. Big thing is not that it is locked up but why it is locked up. Most engines if left for a long time will in fact lock up due to condensation. If the cylinders are not full of water you have a fair chance that you can free it up. I have a 1940 Farmall H I got in that had a 6 inch tree we had to cut down to move it and it was locked up and ATF freed in up in less then a week of soaking it. By the way A WC/wd/wd45 engine will bolt right in
